Hi all,
First time poster, long time searcher here,
First real board (of my design, done a few single sided of others designs with little problems), and just would like some input on the artwork on it. Power is red (component side), and signals are green.
I have a few questions, On my power layer, I have a filled ground plane and in the bottom left there is an area between my two power traces that run up the board isn't connected to the ground signal. Aside from it not being connected to the ground, is it a bad thing to have it there? (It has no connections to components that may think its ground)
Also, if I put another filled ground plane on the signal (Green) side, and put in a vias to connect the unconnected ground plane will it be that beneficial? And then worrying about unconnected areas on that layer (Ground on the signal layer)?
BRad
BRad
