Going 4 layers...
Thank you for setting the record straight, but, was the first paragraph necessary? Or even interesting?
I was merely offering a clarification that while I -- could -- offer some useful information about this specific topic, no matter what it is that I post here, someone will criticize me for whatever it is that I comment on.....just as you have done here!!! So.....I'm right!!!
I will probably just relegate myself to being a "Lurker" on this forum from now on in order to prevent any further forum commotion.
As long as your posts contain a dose of bragging, self-advertising and/or whining, it is not likely to change.
Unless it's humor, in that case I would suggest you take a good look around, no one's laughing.
Of course. When you scratch a wound, it itches.
Typical sulking. The solution is controlling your posts. You have been given enough tips to know what to post and what not.
Of course. That's what I do usually. It seems that many ignore this possibility, though, and have mixed results with ground pour.
It may not be enough to separate grounds with a simple "cut" in the ground pours, depending what you are dealing with, some stronger medicine may be needed. D/A converters come to mind, for layout concerns in this respect. There should be a wealth of reference material on this, at least for relevant eval boards.
Of course. My comment was in the context of standard "baseband" audio. As soon as high-speed logic or RF are mixed with audio, a whole lot of constraints are added.
I designed probably 80 DA, currently doing an SPDIF right now, but that's the first one in 21 years. I worked on the UAC/UAC2 protocol (USB Audio Class) mostly on Asynchronous part of that. I have 32 products of the year awards in 14 countries. I never put separate grounds on a DA, now for higher end products I do isolate so say differential output to 10K:10K transformer to usually a tube gain stage and out single ended. I think so far this year we shipped like 12K*5 so ~60K USB dacs this year.
I think Guido Tent has some good articles about ground planes and digital and analog. TentLabs.com
Your 3D graphics etc looks great but you really don't need to highlight your past work with various state / security outfits etc. at every opportunity. This isn't LinkedIn and you'd be pushing it even there tbh.
Hi!
A bit late, but want to thank you for your advise given here!. Now it is time to apply all that knowledge!.
Jay x
Hi!
I'm going to order 4 layer boards. The manufacturer, by default value, offers top and bottom layers 1oz copper thick, but the inner layers are 0,5oz. For analog audio applications is that normal?, or should i ask 1oz copper on all 4 layers? In my layout, layers 2 and 3 will be GND.
Jay x
Hi!
Jay x
Yes. That is standard PCB fabrication. It's fine.
Hi!
Jay x
[I'm going to order 4 layer boards] -- >> AFTER << you have finished your PCB-design, but >> BEFORE << you send your GERBER files out for fabrication, send me all of your GERBER and N/C Drill files so I can process them through a program I have that will check for -- manufacturing -- errors, which are completely different than what your CAD PCB program DRC checks for. Your PCB design program checks for -- design -- errors, my GERBER-N/C Drill program checks for -- fabrication -- errors. However.....your call.
[you planning to run your house wiring through there?] -- As I write this, I am currently also designing a 4-layer PCB for a large U.S. defense contractor where part of the circuitry has -- 14-Amps @ 40VDC -- going through it!!! I have had to specify 20-Amp types of -- Right-Angle PCB-mounted -- connectors just to handle that.
>> Check out the size of the power-pins on this connector:
In any case.....send me your GERBER and N/C Drill files and I'll check them out for any possible fabrication errors before you spend the money to have your PCB's made. Sound like a plan???
4L Inner copper is normally 0.5oz., while 1oz. Inner is available it triples the cost of the boards, which MAY be motivated by need of high current or better heat conduction.
For normal audiocircuits no need.
What do you want, a medal?
[What do you want, a medal?] -- ****, NO!!! I was merely sharing my current experience of needing to design a PCB with an immense amount of current running through it, that's all!!!
There always seems to be some ******* smart-aleck who just can't simply appreciate that there are those who need to design PCB's that can carry more than a few hundred milli-Amps. SHEESH!!! The young people of today!!! Show me your high-current PCB designs, OK???
