Hey,
i still don't get this:
"You can put the anode voltage at exactly halfway or put it slightly above or below. On each stage, I'm usually not at the halfway point, but only by a little bit."
Do you mean half of actual 290V or you are talking about relation between anode voltages at // triodes?
Yes, // stages in antiphase are another option for lowering distortion as would be local feedback around ECC99.
My problem here is that i don't have access to good lab very often where i could meassure distortion. I can only test it for real by hearing, but this will not tell much if differences are small, even when monitoring is very good. So i normally have to take decisions based on other's opinions or just copy something i already know (which is not giving me much satisfaction anymore). Well, i used to test some of my gear in very good studio because the owner was interested and never charged for hours. But this takes waaay too much time, i could only afford it if gear was for selling.
Because of this i probably should focus on simple design with ECC99, maybe add some local or global feedback.
Btw, do you have opinion about which option (local fb, global fb or antiphase) would give good improvement/difference if i used ECC99? I will probably try them all with time but for now i would like to start with one.
I still haven't "come" to cathode circuit, i will have some more reading about it because i don't really understand how i calculate cathode resistor after i know anode current...
Miha
Miha
