scott2000
I have a Crown XLS1000 with a low input channel...
Anyway, I traced the issue to the display board/input board and specifically to U500B....At pin 6, it's all good, then it all but disappears at pin 7....... very low signal........ (for comparison .06v at pin 7 u500 and .4v at pin 7 u600....)
There's some deal about the Y-input in this area too which I'm not sure if it may have anything to do with my issue............this is the section I'm in on the board and the picture is attached....
ANALOG INPUTS:
The input to the APM can accept 1.4Vrms input and drive the resultant APM output
to a level that drives the amplifier to full rated power into 8G. The differential analog
inputs come from J700 which connects to the MAIN board of the amplifier. The
input XLR, ¼”, and RCA connectors tie directly to this point on the MAIN board.
The following will be for CH2, with CH1 being identical except for the analog Y
input switch (U601).
U600-A,B form a differential to single ended gain stage with a gain of -3.54dB. See
Gain Block Diagrams below. The output of U600B drives the input of U601, which
is a unity gain amplifier that selects either the ‘A’ input (CH2) or ‘B’ input (CH1)
dependent upon the INPUT_Y drive from the microprocessor (Q600 to U601-1).
U601 provides the Input Y audio routing. The output of U601 drives front panel pot
R610 that feeds single ended amplifier section U600-C. This stage has a maximum
gain of +13.86dB as shown.
For CH2, the output of U601-5,6 drives a comparator, U700-B, that lights the front
panel SPI LED when the input signal is >-40dBu. R600/601 provides the DC bias
Should I just be suspect of U500 or could there be an issue somewhere else.....????
Checked a ton of the surrounding components and they seem good..../////
I appreciate any direction......The replacement board is $120
ANALOG INPUTS:
