In the case of using interface outputs as dedicated sends and interface inputs as dedicated returns for connectecting external analog hardware, how do you figure out the latency compensation to use ?
I haven't yet figured the cubase way to do this - I could be wrong, but what I've seen other daws (I'm a long time cubase tragic) is that the latency compensation figure is automatically determined by the software and the figure is set in the same user interface dialog.
In Cubase 5 it appears that you can enter the latency compensation figure but you need to manually determine it yourself ?
The other thing I struggle with is that you can't set an interface input/output to be both an efx send/return and a regular input/output.
My analog channel strips can be used as instrument preamps and so connected to interface inputs as regular ins, but also receive a recorded daw signal via an interface output connected to their line inputs.
So the analog channel strip can act as either a mic/instrument preamp or as a daw 'warming' preamp depending on it's source selection - mic/instrument or line.
But to change the usage from an 'instrument preamp' to a 'track warner' in cubase, you need to redefine the interface input and output away from being a regular input/output (no latency compensation) to an effects send/return (user defined latency compensation).
Which I find to be a pain. ie. changing the connections definitions in the regular input/output page as well as the fx send page. So I end up not using the analog channel strips as 'track warmers' because it seems like such a major production to reconfigure all the time.
I have saved connection definitions for each case and switch between them that way, but still. Lifes short
What I would like is to define a physical input/output as being regular input/output (no latency comp) as well as defined as a send/return (defined latency comp) and be able to select either in the channel input/output lists.
(apologies for long winded description!)
Anyone have a better approach? Maybe Cubase 7 makes these things easier?
