Icantthinkofaname
Ah, so was the right 797 capsule a different center terminated one? Or am I misremembering there being a correct shape 797 one? I haven't seen an actual C800G measurement, just the chart from the manual, so for cardioid, is the difference that there's less of a mid boost (it looks like 5K on the C800G drops back down to 0 dB) and the high boost starts isn't as broad?Takstar (p420) one is closer to Neumann's. The one found in B2 is not the right shape, it is closer to C800 response. The one found in Townsend Labs Sphere is closer in shape to the original, but still bright.
Using brighter capsule but of the same FR shape could be a good idea. Use more of deemphasis filter, you get to the same target frequency response but you get less noise than the original
