tk@halmi
Since good CF opamps are not cheap I suspect, as Brad does, that they use resistor laser trimming to keep offsets low.
I think of the Vbe offset at the output as an asset instead of a problem. It helps bias a good quality electro-cap on the output.
For applications that require one or two amp stages like preamps and compressors having a couple of caps in the audio path can have insignificant contribution to the sound. If you need to chain twenty of them up as in a mixer you need as little offset as possible.
Problems become numerous when we set out to make general purpose discrete opamps that we hope to drop in place of monolithic opamp roles. I have simulated over fourty different opamp topologies and protoyped over a dozen circuits. It is nearly impossible to meet monolithic opamp numeric figures. Then again, most people claim that discrete opamps sound better despite of their inferior specifications.
Notice that CF opamps have a little lower open loop gain compared to commonly used VF opamps. CF opamps tend to have fewer internal gain stages yet achieve very good distortion characteristics.
Do you have a goal for how low the offset should be?
Any targets for open loop gain?
Tamas
Tamas
