HappyHourStudio
Active member
Hi Folks,
First timer here… hi!
So last year I decided to build a little tube console and have come across some of the input transformers I used, so now I’m going to turn the 5 channel 2 bus console into a 10 channel 2 bus console with direct outs and an echo send.
***Disclaimer! I dig the way the one I’ve already put together sounds and the attached schematic could be a little off. I drew that up today to sort of avoid the more modular design of the old one.***
Now… I’m teaching myself how to do this with some much appreciated advice from friends when I get stuck, so there are some weird bits…
The weirdest being how in the old design, instead of a pan pot, I have two volume controls on each channel that go to the left and right cathode follower, which controls the stereo image in a groovy way.
I know for certain that I will have to redo bits of the schematic once I dig into the old design because I ventured off a little on that one…
Want to be able to switch between the solo and summing modes, as I assume that would be the easiest way to go about it. “Solo” mode being a direct out that hits its own cathode follower and summing mode being the Left and Right cathode followers. I kind of wing it on things sometimes… so I know some ideas are probably kooky, but I wouldn’t know! ha It would be great to maybe have a three position switch with one being “solo”, one being “both”, and one being “sum”.
Sorry, long winded… long story short, could anybody be of assistance on a few things:
1.) How and where to add an echo send in the circuit. Would love to be able to go out and back in two a split left and right volume control with a master volume control after that.
2.) What resistors to play around with in the summing network.
3.) I would just love to know what you guys would think in general about it! Ideas and thoughts, criticisms, anything!
4.) Forgot… might as well ask… I haven’t decided if I want to just build two more of the same 12AU7 cathode followers for the left and right “sum mode” or try building something different on the output.
PS-The green board is just my initial layout mock up.
Thank you!
Thank you!
