atticmike said:thanks guys, most appreciated
am I actually good with 63v for the caps?
Mike
PS: Would you guys actually prefer metalized caps over wimas?
63V is fine. Any film capacitor will do.
Mike
ruffrecords said:atticmike said:thanks guys, most appreciated
Mike
Pretty much as close as you can or need to get with 10% tolerance components. The calculated total values are 424nF and 19nF. 330+100=410 which is within 1.5%. 15+3.9=18.9 which is within 0.5%. This assumes of course that 300 and 15nF are exact values to begin with.atticmike said:hey there,
were the 100nF in parallel with the 330nF and 3.9nF in parallel with the 15nF a rough estimation or as close as I can get?
Is it also worth getting those caps for the low end section?
http://www.banzaimusic.com/Mundorf-MCap-630-0-1uF.html
ruffrecords said:Pretty much as close as you can or need to get with 10% tolerance components. The calculated total values are 424nF and 19nF. 330+100=410 which is within 1.5%. 15+3.9=18.9 which is within 0.5%. This assumes of course that 300 and 15nF are exact values to begin with.atticmike said:hey there,
No. Wima or Panasonic Film capacitors will be fine. Getting 3.9nF will limit your options but you will probably find plenty of polystyrene ones such as this:
http://uk.farnell.com/lcr-components/fscex-3900pf-1-160v/capacitor-3-9nf-160v/dp/9520554
and this will do fine for the 100nF if you want to avoid Wima :
http://uk.farnell.com/vishay-roederstein/mkt1813410014/capacitor-100nf-100v/dp/1612246
atticmike said:so you're saying I do not benefit from caps that have less than 10% tolerance at the low boost / cut section and less than 2,5 % for the polystyrene in the HF?
If I was to stick with the 10% tolerance caps, would they be better than wimas?
http://www.banzaimusic.com/Evox-Rifa/
Also, what about those?:
http://www.banzaimusic.com/Nichiden-Audio/
And you're sure those are useless?
http://www.banzaimusic.com/M-Cap-Series/
Andreas Pfeiffer said:What if I am measuring pots?
Will the value then be more accurate (for a stereo version) for example in the middle of the pot also?
ruffrecords said:Andreas Pfeiffer said:What if I am measuring pots?
For the LIN pots the answer is yes. The law of LOG pots is very poorly controlled in manufacture so for all but the most expensive ones the answer is no.
there's only so many ways to say "yes!" knock yourself out. they're film, they're caps, they're good for >50v, they're presumably the right values or close. they're just expensive and probably not worth it in terms of cost vs. benefit. they may also be large and inconvenient to fit on the board, so check lead spacing and diameter against the available real estate. better yet, build one of each and see if you can hear the faint "cha-ching" of the cash register.atticmike said:But they're still formidable for the job since I got a few lying around from a tube project? Talking about the mundorf.
