[silent:arts]
I wouldn't feel comfortable with AC heaters and a rectifier / voltage regulator next to it (but what do I know) :Silvas said:But it is possible to steal some voltage from the heaters secondary to do this right? running the relays at 5v ? or i can use a second toroid (have lots of 10va anteks lying around).
a second transformer would do the job for sure (but you won't need 10VA)
you could wire a switch instead of the realays.
you could skip the "In" (or bypass) and solder bridges at the relays too.
many ways ...
