benlindell
OK cool, so I switched them, I'm still getting the same readings everywhere though. Just curious, what does having the AC power be out of phase do to the unit?
benlindell said:I think it may be time to take it all out of the case again so I can get to the bottom (pun intended) of this.
correct is 250V each halfwave,benlindell said:... Just curious, what does having the AC power be out of phase do to the unit?
Cardinen said:
sonicwarrior said:Finally someone with a case from the evil man. Where did you get the lamp/LED holder from?
Any problems with the power switch in the middle?
Cardinen said:Ahaha why evil man?
Cardinen said:The VU lamp are simple a blue led above the meter.
sonicwarrior said:I didn't mean the VU meters but the lamp in the middle. I don't know where to get a lamp/LED holder that fits this f****ing big hole.
Good to know I got the heaters right. The wire at the top is the relay ground. I'm planning on going the whole thing joint by joint and double checking everything.bernbrue said:Well, the heater wiring look ok for me, but what is that wire on top of the picture doing there? I would also check a few solder points for bad contact or even shorts. I marked a few spots in the picture.
regards
Bernd
Yes it does[silent:arts] said:Ben, does the right channel passes audio in bypass?
(just give the unit no power and check)
