Lowfreq, try swapping T4bs see if the problem follows the optos?
[silent:arts] said:yes - no power to the relays = bypass.
this way the comp passes signal even if the fuse blows
+100100MicDaddy said:This may be very obvious but if you use the molex with crimps, don't buy the crimps on a reel. I overlooked this and spent quite some time cutting and working them over with a dremel.
desol said:You need quite a bit of space as the unit runs hot....or fairly warm and needs room for shielding/wiring. A 3u case like the one pictured in mine and other builds(page 1) is what i would probably recommend. You could put it in a non-rack box, say, with a handle on top...but it wouldn't be much smaller in terms of length, width or depth. Have a look at some internal pictures...you'll see there's not much room else wise.
use www.nrgrecording.demartthie_08 said:last question for today: what the hell happened to nrgrecording.de ?
