band_master
- Joined
- Mar 14, 2011
- Messages
- 68
@frazzman
Did you reflow the tube socket joints and the molex connector joints under the PCB? you should definitely use shielded wire for the limit/comp switch. moving that wire around and even touching the switch i have found it is noisy even with a shielded pair. have you tried replacing the female molex connector for the limit/comp switch?
