bernbrue said:Hi,
would be nice to have bigger pictures of your built. The picture you posted cannot be found (Error 414). I had a look at the video. A few things to consider (maybe too obvious, but we have to start somewhere):
< No audio is being processed at all (compression, limiting etc)>
Maybe a silly remark, but did you do the heater wiring underneath the pcb?
Try to make your left channel work properly. Then compare it to the right channel
- Left meter does not output vu signal
3K6 resistor installed? Toggle switch wired correctly? Molex connector plugged into the right place?
I bet there are some very simple things gone wrong! Read the wiring & calibration guide attached.
Bernd
thanks, i fixed the pictures. Yes i read that guide and i soldered all heater wires as the manual says. Voltages are okay.
What 3,6k resistor do you mean? Wiring is correct and molex as well.
