Having an odd issue with a fresh DLA@A build, running out of things to try.
Unit functions perfectly, signal quality is excellent, but there is a buzz in the audio that interacts with the gain pot. It is pretty loud with the gain low, decreasing to a total absence (null?) at around 3:00, the coming back in to all the way up.
Shorting the input makes no difference, tapping audio before the output tranny makes no difference.
Tried it first with the Edcore P/T on the back of the unit, then then with an outboard all DC power supply, then a bench supply, no change.
No hum at all, audio path is extremely clean when at the null point.
I have built at least 6 LA2s, point to point, a Drip, and so on. Never encountered this issue before.
All components are correct, I have tried different tubes...
Any ideas?
