DALI IKON SUB amp issue 00-00247-01
tadejm
Active member
Slovenia
Hello!
I'm repairing DALI Subwoofer with amp board 00-00247-01, which was injured by lightning.
The customer said that it was just humming after that.
So I opened it, checked the board (the board looks perfect, without any damage) for possible shorts on transistors, capacitors, ... but nothing unusual. Everything looks fine.
However, if I look at it with a thermal camera, when I turn it on, the C3117 transistor gets abnormally hot (200+ C), and R126 and R157 start smoking. Although the C3117 npn transistor is tested OK, I replaced it with a new one. I also replaced pnp - A1249 and both resistors R126 and R157.
But the problem remains the same.
Does anyone have any advice on what could be wrong?
    2.7 MB
Hello!
Hello!
Hello!
Hello, I got problem with a customers sub, ATOMIC. Power but no sound, speaker works, tested with a battery. Now I see you had "247-01". Where did you get it ? Probably help me get this bellow ?
00-00245-02
00-00247-01
00-00248-01
I don't know how to troubleshoot with multimeter, I'm learning but as a start the schemes would be perfect and now thx to you I got 247
