zamproject
- Joined
- May 11, 2010
- Messages
- 1,590
Hi all
I'm troubleshooting my JU60 that have issue read/write memory
I think I find the data line of the DB bus which cause problem, bit 4
Those 8 lines read/write pot, set switches (read is from matrix on other ports) and read/write RAM
At this line I can scope the cycle , and there is one data which is NOT at 0 or 5V but somewhere around 3
It's also the line that set/latch switches for chorus II and HPF, the exact data that don't store properly.
This line connect from/to uPD to a latch (40H373), which handle 8bit pot DAC, and RAM address,
to a flip-flop (40H273) that handle switch data out, and finally the RAM data I/O
The question is about the suspect.
Can an input from a the CMOS D-type latch or flip-flop be -altered- only at clock or control port call ?
I mean if a -cell- is dead I should have this -pulldown- all the time right ?
But this DB line is not always pulled down, but only at on bite of the uPD cycle.
Same question for the RAM, can a CE or W/R command alter the I/O buffer behaviour ?
See attached, suspect DB line in red (blue is further latched/flipped data)
Zam
Zam
