martthie_08
I use both sequencers extensively, it totally depends on your projects and needs.
Protools has some strong points in that you don't have to worry about a second mixer for cue mixes, like on most coreaudio systems (don't know how the apoggee is integrated). I tend to do the monitoring through PT and it is very easy to punch in and out in realtime to fix parts that need to be fixed. The playlist system is great to keep track of the different takes, the comp feature in logic does not work for me, because you can't make edits within the comps.
Logic on the other hand is really great for composing and is very efficient and well integrated into Mac OS. Logic has some nice Plugins builtin (still wish I had the EXS24 in Protools HD) and is a nice app for mixing. For recording I find it hard to organize large sessions with tons of takes and mostly do that in Protools. Editing audio is fairly straightahead, but I miss the "nudge region" feature, like in Protools where you can just slip the contents of a region by a couple ms.
Regarding sound quality I can not say one is better than the other, it mostly depends on the quality of the plugins and your gain staging working ITB. For converters both systems give you lots of choices, I work with the Digi 192 at the moment, but plan to upgrade to SSL Alphalink for more Analog I/O. Lynx converters also seem to be working for a lot of people, both can be used with Logic or Protools HD.
