Golgoth
Hi everyone,
I once again have a faulty DBX 118 I am trying to repair (not the same unit as my 2016 thread).
Initially the unit was not passing audio. I replaced every capacitor except the ceramics and every IC on both the motherboard and the RMS and VCA cards.
Now the unit is passing audio, and the RMS detector seems to be doing it's job and correctly reacting to "above" and "below".
Correct voltage on the PSU +/- 12V C4 capacitor, and on the card connectors pins 7 & 8.
With both knobs at 12:00 the audio sounds "correct". But if I try to set the threshold to either low or high position, and then turn the compress/expand pot, I am getting complete distortion of the signal where all the original signal is replaced by noise. The issue is worse in "above threshold" mode where distortion is maximal at 11:00 or 1:00 already. Takes a little more turn to reach the same level in "linear" mode.
I checked the signal with a scope and a sinewave, result below (both knobs at 12:00 position first, left/right setting with a crazy pic in the second picture).
Any idea what to check next or what could be the distortion's cause?
Does anyone have a working unit we could compare trimmers' voltages for example? I'd also like to check VCAs pin 2 "EC" voltage which is variable. The issue here is I have no idea of what the correct voltages should be at most points in the circuit except for the +/- 12V rails.
