Started building this guy tonight and I have a few observations.
1. The silk screening vaporizes if you rub up against it.
2. The four mounting holes on the corners need to be considerably larger,
preferably to fit a 6-32 or 4-40 sized screw or mounting device.
3. As pointed out earlier, the hole spacing for the dbx RMS/VCA modules is in correct.
4. Suggestion for silk screen, instead of 4.7K use 4K7, decimal points are hard to see.
5. The pads for resistors could be larger, but this is less of an issue and only if space
permits.
6. AC transformer and Power connectors should be larger sized to accomodate higher
currents and larger wire. Maybe double sized/spaced.
That's it for now, will report back with more as I continue on.
Mark
