damnyankee
ssltech from another forum recalled this about the dbx 202 vca (the later black can version also found in the 160/161 VU):
"dbx found that the transistors had to be closely matched, and also be extremely well-coupled thermally. Eventually it was decided that monolithic construction was the best way to achieve this... hence the 2151 package type.....there is a large white 'thingie' around some of the transistors. If I recall correctly, it's absolutely crucial to maintaining the stability of the distortion trim. Otherwise you'll find yourself with a unit that just sounds plain old bad [which may explain why the transistors are glued/potted in the "white thingie"].
-please, please please bear in mind that VCAs got a really really bad name because of the distortion artifacts in a time when pleasant tube distortion was a recent -and strong- memory. By all means try to build it, but I hope everyone knows that there are some pretty wierd, voodoo things going on around the blackmer cell, and many competitive "mee-too" VCA manufacturers set up at the same time foundered owing to not being able to make one without some near-catastrophic sonic charateristics...
Try trimming the distortion trim on any that you do build at different gain-settings, and then warm them up with a hair-dryer... then take a distortion reading... you might begin to understand how hard it is!!!"
We need to pay very close attention to this when we start building the 200 VCA...
