OK, If you are not allowed to post it
, please only say - is my schema accurate? (except part no's)
Still thinking about soft limiter, it could be little more softer. We can add more diodes in series with existing ones (to add small voltage shift of it's treshold voltage) and one more diode with resistor in series and this combination add in parallel to two diodes in series. The area of transition to the limitation will be rounded by this. Theoretically we can add many stages like this to make limiter nicely soft
And if I engage in a flight of fancy, it would be possible to make these resistors dynamically variable depending on the level of the signal using optocouplers with photoresistors... yeah, I'm gonna make my own comp-limiter 8)
But after listening test I can say - limiter with one resistor sounds much better than original. Maybe there are still too many higher harmonics, with circuit described above it could be little better.
Some screenshots:
original dbx, with limiter activated at 20kHz
upgraded dbx, limiter dtto (note smaller delay of output caused by wider GBW of opamps)
original dbx, common mode rejection for 10V square with 7ns edges; chA=2V/div chB=20mV/div
upgraded dbx, CMR dtto
