Kingston
jef111 said:Yes, I know, but paralelling of VCA's is for another PCB it would be crazy here...
Add an 8-pin socket and make an adapter. I did this with GSSL too. Plenty of room in the PCB in this area for it.
Only difference is the xl uses a differential op amp input and the plain 166 is an unbalanced opamp input. You should be able to trouble shoot the unit with 166 schematic.I have a issue with unstable output level on the right 2nd channel.
Level spikes!
Screenshot shows when i engage bypass - everything's fine.
No settings (knob tweaks) are affecting this problem.
I try both TRS and XLR cables.
Left channel is fine.
Please help to find problem.
Am electronic rookie. What switches you talking about? Bypass switches etc?Only difference is the xl uses a differential op amp input and the plain 166 is an unbalanced opamp input. You should be able to trouble shoot the unit with 166 schematic.
99% of the time you will find dirty switches that cause problems such as yours.
