sahib
3U DBX 904 Noise Gate front panel + LED meter board.
Good candidate for a 500 series compressor project using an off-the-shelf proto board. Or get a new laser cut facia for a mic-amp etc.
https://www.audiomaintenance.com/acatalog/AML-07-073a_extended_info.html
You will need to remove the two existing mounting screw inserts as the board will have to sit inside the PC fixing bracket. I have pointed it out in yellow arrow.
Schematic for the LED meter card is readily available. So, modify it to your purpose.
GBP 20.00 each module plus shipping and paypal.
2 Modules available.
