That is my votesquarewave said:Just so that I'm clear, is the 2181A is the absolute best performing VCA available?
That's correct. Apparently, the V8 does not allow the use of symmetry trimming; hence the use of the 2180.squarewave said:Just so that I'm clear, is the 2181A is the absolute best performing VCA available?
If there is interaction between parallel VCAs that could complicate any trimming process.abbey road d enfer said:That's correct. Apparently, the V8 does not allow the use of symmetry trimming; hence the use of the 2180.
Yes. Symmetry trimming can be positive or negative. Improving one chip may detriment another.JohnRoberts said:If there is interaction between parallel VCAs that could complicate any trimming process.
You are right. It's made clear on the schemo. that would confirm that they use the 2181.moamps said:IIRC, in DBX202x, consisting of 8 paralleled VCAs (dbx2150?), only one VCA is trimmed.
beatnik said:Thanks everybody for the information.
On the V8 the symmetry pins of the vca ics are left unconnected, except one (U4)
So that means the 2181 trimmable version is used ? And only one vca ic is being trimmed ?
There's no doubt the trimmable version is used, at least in position 1.beatnik said:but then I cannot explain why on the first vca pin 4, which is the symmetry, there is actually a connection to the main board.
If it were the non trimmable 2180 then pin 4 should be left unconnected right ?
Register today and take advantage of membership benefits.
