oran.outan
Hi All
I've see some thread talking about but I'm still a bit confused.
I'm building an 2 channel Line to Mic circuit (globally send line output from soundcard into Mic pre) and I like to DC protect the signal chain against +48v. (some of the stupid things that can happen so easily). So I like to put a transformer for isolate the circuit, but my skills are a bit limited and all of the transformer I have used on the past are noted "Do not pass DC through windings". So if I understand +48v will 'burn' them !
Do you have any recommendation about which or type of transformer to use ! I will need a 1:1 - 150/150
Is that situation need gapped transformer ?
thanks
0-0
thanks
0-0
