mikep
[quote author="RogerFoote"]
Did you look at the "Hybrid Op Amp" schem?
With it, you can run the unit with or without the servo. And you will most definately have more than a few mV of offset with the servo disengaged.[/quote]
yes I looked at it. I have built similar output stages. as long as you AC couple the input there should be very little DC offset. *much* less than .6V. IMO this topology can be even be DC coupled with no servo. how much closed loop gain did you have when you measured that offset? just trying to help. based on my experience, that sounds screwy.
edit: I didn't mention, I only like this topology for low gain INVERTING. up to 20dB gain. that could be part of the explanation. roger, are you using it non-inverting?
