DC Voltage Doubler From Phantom Power
sr1200
GDIY Supporter
Long Island, NY USA
I'm trying to figure out the best way of going about getting somewhere near 100v to polarize an old mic with the least amount of components.
Can I build something to double the phantom source, or should i build a dedicated power supply? (was thinking a DC-DC boost, but cant find one that will take 48v, but could knock down the 48 to something lower to work with the constraints of something like a UC3843/UC3845.
Other details: Its an old Grundig Mic that needed around 100v to polarize but didn't need a "pre" pre.
Don't forget that the 48v is sourced through 6.8k resistors, so it is not actually 48V available to use once you start drawing any current.
If you want something simple Analog Devices has some high voltage charge pumps which may work. Might depend on how "near" to 100V you actually need, but doubling voltage is pretty straight forward with a charge pump.
I have no clue how much current this would draw. The high end of things pulls 10mA (earthworks). Since this thing is probably in the neighborhood of 70 years old, there isn't much documentation on it. The capsule supposdly has a 50-15K response. Im just really curious as to what it sounds like more than anything. Not expecting anything great at all.
