zamproject
- Joined
- May 11, 2010
- Messages
- 1,516
ricardo said:The back diaphragm is part of the cardioid acoustic back access for the front diaphragm.zamproject said:what are the influence in cardio mode coming from back diaphragm, can a sucked back diaphragm mechanically interfere to the mobility and moving specification of the front diaphragme and/or alter the backplate polarisation?
If it collapses early, it means the tension is too slack. Cardioid response & pattern will change. This happens even if the back diaphragm is not polarized so it has not collapsed. The slack diaphragm is enough.
tks Ricardo.
so i can consider my capsule completely dead, even with one good diaphragm in cardio use only :-\
another question, how a M7 design manage the atmospheric pressure variation, i don't see any hole letting change the inside pressure after the diaphragm mounting, but maybe it's not so important?
