Hey there, having an issue using the new apple silicon protools build 2023.3 with apple silicon UAD on a Mac Studio running the latest Ventura (13.4). Stoked on this new machine, everything is running very fast and smooth. I know this is new software on new hardware.
In the past, pro tools delay compensation has worked fine automatically with Apollo when using hardware inserts but with this new setup, delay compensation is working (showing in mix view and delaying a certain number of samples) BUT there is an audible phase issue.
Test case: When I have two identical audio tracks playing at the same time to the same output, one with hardware insert and one without, there is an audible phase issue indicating incorrect amount of delay between the two, even though the insert does trigger delay compensation on the track. I’m testing this with just a direct patch cable from output to input. No outboard.
I have the channel muted in console etc, I’ve troubleshooted all the basic stuff. can’t figure out what might be causing this.
Buffer is 512, 48K sample, Burl bomber as clock. I’ve tried different buffers and input delay in console as well as a couple of other things, all yield different flavors of phase issues.
Any ideas where to look? Anyone know how I ensure PT is delaying the proper amount for my interface and settings? There are essentially zero settings in PT for tweaking this stuff. Thanks!
I posted this in the Avid forums as well.
