pvision
I've seen quite a few Effectrons but not seen (or maybe not noticed) this before. As they arrive they're setup for 110 Volt but have four solder pads to change voltage. Normally the pads are linked L-K and K-J for 110V and you change this to K-K for 220V. So far so good
This Effectron II ADM 1024 (one of dozens of similar versions of the Effectron) has a second set of solder pads (marked 100 / 200) beside the main PSU cap that appear to link one end of the rectifier bridge to the positive of the main cap (I think this link is marked I on the schematic)
I can't quite get my head round this - any suggestions?
Quick explanation of the PSU: it has two sets of secondaries, two rectifier bridges, three 7812s and a 7805. The #2 secondary feeds a 7812, the positive output of which is tied to ground so giving a -12V supply. The secondaries don't have centre taps and #2 secondary is electrically isolated from #1
When the primary is wired appropriately the transformer doesn't care whether the supply is 110V from a US socket or 220V from a UK one so why change anything?
Is this 100/200 link a red herring, unrelated to voltage switching?
One thing to notice is that the schematic shows voltage inputs of 100, 200, 110 & 220 Volts at the power input which suggests (to me, at least) that the link is voltage-related
I don't have a specific schematic for this model but have attached a diagram for another Effectron
