Hi !
2-3 years ago i fixed a Denon DN-X100 by replacing the 2 channel sliders and also the crossfader.
The service went smooth and testing the mixer using Line Inputs for some time seemed perfect.
Now my friends took it back to me again for repair, because they tested it with Phono Inputs and they said something about them was KO.
It took me some time to borrow a Technics 1210 to test the Phono Inputs and when i did initially it seemed everything was fine. But then I was very surprised.
It took around 1, maybe 2 hours of continuous use for the issue to show up.. :
at some point, the audio simply stops. The mixer don't show any issue, all commands respond, but simply the audio coming from the Phono Inputs stops.
During the issue showing up, i swapped the Technics on Channel 2 and the issue was still present, so when it happens it influences both Phono Input channels.
Powering Off the mixer and then Powering On (Hard Reset) even without waiting seconds before powering on, magically fixes the issue !
1) What kind of issue can this mixer have where suddenly BOTH Phono Inputs stop working at the same time and powering off/on fixes the issue ?
Of course the issue showing up is totally random. It may happen after 1 hour or 2 or 3...
I attach the full Service Manual which is done good and has schematics and parts list.
2) Looking at the schematics where would you start by debugging this kind of issue ? Which test points you would check ?
3) Considering the issue is random, what is a good methodology to catch this kind of issue when they show up ?
(a turntable cannot play vinyls for hours, and anyway the mixer must be open without the fader board installed to be able to access electronics of Phono Inputs..)
I still need to take some time to analyze schematics in deep. I have a Tektronix dual channel scope (2215 60mhz).
Judging by how the issue is random and what it is i tend to suspect something about overheating ?
some kind of overloading that happens in some digital lines and somehow affects both Phono Inputs ?
mmmmh.....
Thanks !
mmmmh.....
Thanks !
