Well, you COULD use the continuity indicator on your multimeter to make sure the wiring's in one piece, between the mic XLR in and the transformer, check the resistance of the transformer's primary and secondary windings, then check the wiring between the latter and the input amplifier (IC1, TDA1034N).
Triple-checking that all the opamps DO receive the power they're supposed to (on pins 4 & 7, as per the "power rails" section at the bottom-middle of the schematic, viewed in landscape), would also help.
