Design for my job at station
Johnny1234
Dupont, PA
Hi all any advice is greatly appreciated.
I need to modify a box at work. The original has an amplifer driving a 2 inch 16 ohm speaker.
I need to:
1 Add a line out
2 Have a switch to alternate between speaker and line out
3 Add a volume control for the line out and speaker
Below is a little diagram of my thoughts. All ideas are greatly appreciated, but simpler is better.
Many Thanks
    1.7 MB
1 Add a line out
How is the signal delivered to the amplifier in the box? Do you already have access to a line level signal coming in, or the speaker is part of something else and you cannot easily access as line level?
What is the level sent to the speaker? (presumably pretty low since it is a 2" speaker, but you will still need to know typical and max to determine how to adapt to line level).
What nominal "line level" do you want? What consumer equipment considers line level and what pro equipment considers line level is quite a bit different.
The box is for a college game show that we will host. Signal is derived internally, it just beeps lol. I don't have easy access to the line level input. Speaker level very low I would imagine about 1 volt. Nominal level would be for pro audio input.
    3.5 MB
Actually, the pot is in a good location for the mod. However, the way it's drawn means the amplifier's output will be shorted when the pot's setting is turned "off".
Bri
Great point, I will put a 100 ohm 5 watt resistor in series with the wiper of the potentiometer.
What are the specs for the input being fed from the beep-o-matic <g>? +4 dBu or -10 dBV line level, low Z mic level, guitar amp instrument level, etc. etc.
Sorry....couldn't resist....
Bri
LOL I love it made me smile after a tough week at work. Input will be like a Makie line input 10K ohms.
OK....curious how you figured that voltage spec. Oscilloscope? Regardless, seems like a step-down xfmr would be a good idea.
I'll pick this up later after I have some tacos for dinner<g>.
Bri
Thank you Brian, Yes measured on a oscilloscope. Beeps to fast to measure with rms volt meter.
OK.....peak or peak to peak?
Regardless, maybe something like a xfmr "rated" for 10K:600 Ohms. Nice step down ratio to drop the signal to a reasonable level. I seriously doubt you need the beeps to slam the mixer's VU meter....lol.
Damn....their prices have gone up:
https://edcorusa.com/products/wsm-s...-matching-transformers?variant=41117605298363
What do you have in your junkbox? Like, any xfmrs intended for "70 Volt" loudspeaker distribution systems (ie the 8" speakers attached on frisbies in the ceiling tiles at Applebees)?
Bri
@Johnny1234 ....Just noticed in your first post that you wanted the volume control to vary BOTH the speaker and line output levels. Now I'm second guessing myself on everything! lol
Without "being there", I have a variety of "what if's?" in my poor dumb brain!
I've worked off and on at commercial radio stations over decades and many "one off" projects came up. In YOUR case, is the little internal speaker in Beep-o-matic ONLY used when not on the air (ie, audition in the control room)? Or, is it also needed to hear beeps for anyone sitting in the control room who don't have headphones AND also feed into the mixer?
Damn....I'm over thinking this! <g>
Bri
ARRRGH! I looked at the picture you posted...and see a switch for "speaker"/"XLR" and a level pot of some sort, and a male XLR. ???????????????
In post #4 you said "Speaker level very low I would imagine about 1 volt."
Post #5 you said 17V peak into the speaker. Converting to RMS (12V) that is 9 Watts into 16 Ohms which should send a 2" speaker cone ejecting from the box as confetti.
Now exactly what are we doing here? I am just a old, cranky tech! ;-) But, I am 10000% certain an output transformer should be used for galvanic isolation in this science fair project <g>....and I say that with a warm heart.
I worked part time at a struggling FM station when I was a Sr. in High school (1972) and had to figure out how to interface one of these beep-boxes (I built it from a magazine article and mail order kit) into the KWHP production room system.
https://www.ebay.com/itm/156469073284
Bri
First rule of a successful engineer is make sure you give the customer what they need, not just what they asked for.
If it was 17V peak-to-peak instead of peak that would only be about 2W, more reasonable for short term power into a small speaker.
A lot of this depends on the headphones that you will be using, Some of the low impedence 8 Ohm Sony headphones will get the same power as the speaker, and be horrendously overdriven, High impedance headphones like the 120ohm or so AKG's will be right in their range 1 to 1.5 volts, so the padding of the headphones out will depend on the impedance of the headphones used. To illustrate, we used to use 50 Watt (about 40V @ 8 ohms) power amps to run the headphones in a large session with up to 40 AKG phones sets wired in parallel on the power amp output with no padding, because it did not need it, however it is prudent to have at least an 8 ohm resistor in series to protect the amp from a low impedance situation like a shorted headphone cable. Modern transistor circuits conveniently do this as power output goes up as impedance goes down. So just by using high impedance headphones with this kind of amp, with a safety resistor, you may not need to pad the phones out. Also consider using a jack with switches in case you are alternating, not simultaneously using the speaker and headphones.
