midwayfair
I'm doing a wah pedal repair, and the customer was able to partially read the pot for me but missed the crucial word "Audio" on the pot. This company marks their Audio taper pots with a B, adding to the confusion. We found this: Radiohm 20mm Potentiometer 100K Lin A Dual Stereo 6.3mm D Spindle B8 20G Z185 | eBay but once I got the pedal in hand I discovered it was the wrong taper.
The height between the two rows of pins is about 13/32" (I suspect this pot is Imperial measurements). The threads are 3/8" tall and the shaft is 1/2" tall x 1/4" diameter. The pins are 7/32" between the outer points.
