Difference - Axial vs. Radial caps
cactus
Mobile, AL
I'm trying to get parts for the 9K project (among others) but some of the BOMs don't specify type.
How do you know what type you want? Axial or Radial? Ceramic or Poly...?
Thanks for any input.
...also, check the PCB layout- e.g. for electrolytic caps, if the hole-spacing is close, you need a radial, and if they're far apart you need an axial.
As a general rule ceramic caps are usually used for lower values <1000pF (1nF) -BUT they're often used in values up to 100nF (0.1uF) in power supply decoupling roles.
If the cap is in the audio path, I'd stay away from a ceramic. If it's between a power rail and ground, then a ceramic will do the trick.
Sometimes small-value caps are needed for compensation- connected between two pins on an op-amp (NE5534 etc) or across a feedback resistor to limit the bandwidth. A ceramic can be used here, but for stability a polystyrene or even mica (in high-stability situations) capacitor can be used....
Often a search of the forum will bring up a good picture of someones project they've done, and you can have a look at the caps etc and see what they've used in a specific project.
:thumb:
Mark
