Discontinued connector options
Noth
Active member
Fr
Hello,
I've designed an "MCI JH600 preamp" PCB which is supposed to fit on a Channelstrip.
Unfortunately, the connector used is unknown (at least to me !) so I'm trying to figure a way to replace those.
Currently, my PCB has holes with proper spacing and diameter and the best option I've found is to use steel nails as pins!
It works fine but well, it's not super clean and steel is clearly not made to be solded on a PCB.. (At least no-one will break my pins :) )
Pins characteristics are:
- Diameter : 1mm
- Length : 24mm
Does anyone has some suggestion on where to source a proper equivalent pin?
I though about cutting segments from a copper (maybe not rigit enough) rod or brass (not sure if it can be soldered as it).
Thanks for any advice!
Original connector:
Pin spacing is about 3.6mm.
On my original PCB I was using 3.96 thinking that it could eventually be standard but sadly that was a bit too large
I just check on my PCB gerber, the spacing is actually (center to center) 3.8mm.
Since the difference to 3.96 is subtle, you're probably right!
I will test again with "standard" Molex connectors
Thanks for your help !
Whatever you do, spend the extra $$ and get the GOLD PIN version. The tin pinned Molexes are the bane of every MCI product ever made!!
