Discrete OP Schemtic for +/-60 V
Madman
Active member
Germany
Hello All, :grin:
i was searching for a Schematic of a Operation Amplifier with +/- 60 V OperationVoltage.
Can anybody help me? :roll:
Nice Day!
Dennis
Basically any discrete opamp will work if you use suitable transistors and keep the dissipation low enough. The second constraint get's hard pretty soon, especially if you want an short-circuit proof output.
I have one for +/- 40 V in development--preliminary release:
[removed]
Skip Q11/Q12 and R10/R11 if you try to implement that one. Q1/Q2 are 2SA970BL, Q9/Q10 MJE172/MJE182 and R1/R2 could get paralleled by a 22 uH each for lower noise.
I'll post an updated schemo with more changes if you are interested--but need to fix that :evil: Wind*ws first...
And you could check www.apexmicrotech.com for schematics and buyable opamps.
Samuel
Agree with Samuel on Apex---they have been specialists in HV op amps for many years now. Be careful about taking their schematics literally however.
For the highest performance output stage I have seen some Sanyo transistors for video applications that look quite promising.
[quote author="Samuel Groner"]
Tell me more! :grin: (Do you know Eliza?)
Samuel[/quote]
Hmmm---now that I look at them they are only 80V Vcbo. Maybe they have some higher voltage ones that are almost as fast. This pair is the 2SA1402/2SC3596.
Who is Eliza?
> Who is Eliza?
I met Eliza in her preteen years. She looked like a TeleType but really lived in a mainframe. She was a better conversationalist than most people I knew.
http://www-ai.ijs.si/eliza-cgi-bin/eliza_script
Eliza: Hello. I am ELIZA. How can I help you?
You: I need a good BJT for an opamp.
Eliza: Why do you want a good bjt for an opamp?
You: So that my clients will love me.
Eliza: Why do you say your clients will love you?
You: The sound will be wonderful.
Eliza: Please go on.
You: Harmonious and powerful.
You: And there is another thing....
You: I hate mice in my gear rack. +/-60V will kill the little pests.
Eliza: Why do you say your gear rack 60v will kill the little pests?
You: Edison proved it, to spite Westinghouse.
As you see, she has stock phrases. This version uses "Please go on." a lot; Samuel has met her when "Tell me more!" was a favorite conversational tidbit. Eliza has a brother who pretends to be a psychotherapist.
ELIZA--A Computer Program For the Study of Natural Language Communication Between Man and Machine
http://en.wikipedia.org/wiki/ELIZA
Oh oh oh yes. Of course. She says tell me more a lot.
I thought maybe Eliza was someone Samuel knew at Sanyo :grin:
At a party years ago we had two programs talking to each other, one of whom was Eliza. The concept was great but it didn't get too far.
Hello jakob,
i need the schematic for +/-60 for a passive EQ, for example the SPL EQ´s working with 120 V for a bigger Headroom.
For this operation with a passive EQ was i searching for a OP as Pre AMP, with +/- 60 V or other.
Dennis
Hell--700 MHz ft for a 8 W!
I need the schematic for a passive EQ, for example the SPL EQ's working with 120 V for a bigger headroom.
I suggest that you stay with +/- 40 V; this is only about 3 dB less headroom than a +/- 60 V and it is much easier to design and to source good parts for.
IMO supply rails higher than +/- 24 V are pointless and usually lead to design compromises with worse audio performance. My high-voltage opamp is basically a "fun" project and not because I believe that there is any advantage in using such high supply rails.
BTW, I believe that the company we all know of uses opamps similar to this one: [removed]
Replace the two current sources (Q5/Q6) with dual transistor ones and Q7/Q8 with modified darlingtons and you get the same transistor count. No miller compensation probably.
Samuel
[quote author="Samuel Groner"] Hell--700 MHz ft for a 8 W!
Samuel[/quote]
Moto used to make some higher-voltage comparable-power parts that were also quite fast, for the same application, but evidently abandoned the business even before they sold that portion of the company to On Semi. Sigh...
