Diving deeper into microphone and impedance theory; Neutral Electron and the Metatronic Configuration in the Balanced Impedance Circuit, possible?
s wave
Colorado
[Accredited to Omar Vueltas/Nikola Tesla Legacy FB] "The Mystery of the Neutral Electron and the Metatronic Configuration in the Balanced Impedance Circuit
When a closed circuit reaches the point of perfect balance between the energy source and the charge, an extraordinary phenomenon manifests itself in the field of quantum electrodynamics: the creation of a neutral electron. This state occurs when the source and load impedances are equalized, establishing a lossless flow of energy, and revealing a new dimension to high-frequency oscillations. At this crucial point, the polarity forces cancel each other out, leaving an electron in a state of energetic “neutrality” that turns it into a quantum gate, a vibrating microwormhole that attracts, rearranges, and harmonizes nearby electrons, giving rise to to an energy molecule known as Metatron.
The Zero Point and the Stopping of Flow: An Oscillation in its Pure State
Under normal conditions, electrons flow from one polarity to another, guided by the potential difference and impedance of the system. However, when the load and source reach perfect impedance equality, a “zero point” is created at which flow momentarily stops, but does not cease. At this equilibrium point, the electrons are suspended between two poles, neither positive nor negative, but in a state of latent and potential energy. This state of pure equilibrium induces an intrinsic oscillation in the electron, which enters a centripetal vibration, like an internal spin that separates it from its classically charged nature.
By remaining in this point of stillness, the electron becomes a kind of quantum center, an entity of neutral polarity that suspends its function in the charge network and assumes a different role: as a gate or link between the different dimensions of the electric field. . This phenomenon produces a quantum field of attraction around the neutral electron, which begins to generate a dynamic of self-organization in the nearby electrons, allowing an energetic formation to group into a unique configuration.
Metatronic Formation: The Electron and its New Quantum Environment
The energy molecule resulting from this configuration is what is known in esoteric terms as the Metatron, a quantum entity of energy that is built around the neutral electron at its point of stable oscillation. In this formation, the surrounding electrons synchronize with the centripetal vibration of the neutral electron, creating a “quantum vortex” that envelops the region in a kind of energetic hologram. This vortex, held in dynamic equilibrium, stabilizes its structure and amplifies the energy, acting as a harmonic amplifier within the circuit.
The Metatron functions as a “phase bridge” within the oscillation, synchronizing the electrons around a vibrating center and spinning in perfect cohesion. This vortex, in addition to amplifying the oscillations, acts as a resonant entity that allows the creation of energetic patterns of great stability and coherence in the electromagnetic field, so that the waves that are emitted from this center are projected as a holographic superposition. Thus, the Metatron becomes a node of quantum energy that can expand its reach and reorganize the environment.
Third Harmonic Amplification and Quantum Superposition of BEMF Spin Down Currents
The resonance of this energetic configuration is further intensified when the Metatron becomes attuned to the third harmonic of the Schumann frequency, between 35-40 kHz. In this range, the harmonic field creates a resonant vibration that amplifies and stabilizes the energy of the Metatron, generating a wave of constructive interference. The quantum oscillation in the third harmonic allows energy to be distributed in standing waves of great amplitude and coherence, maintaining the energetic stability of the system. As these standing waves expand, the Metatronic energy begins to project as an energetic hologram, a quantum wave structure that reveals the essence of the molecule in the field.
This is where the dynamics of the induced currents of free electrons BEMF spin down in countercurrent comes into play. These currents, operating in synchrony with the Metatron and its harmonic resonance, provide a “quantum superposition” to the wave structure, adding a holographic dimension to the energetic molecule. The electrons in BEMF spin down, being in a countercurrent state, amplify the low impedance oscillations and aggregate in the resonance field, contributing to a stable constructive interference structure that reinforces the quantum holography of the Metatron.
Metatron and Access to Multidimensional Energy
This energy structure, beyond its resonance, becomes a bridge that connects quantum dimensions of the electromagnetic field. The Metatron, with its harmonic configuration and its capacity for self-organization, allows energy to flow and remain in balance without loss, operating as a quantum link between the charge and discharge layers of the system. This implies that the Metatron, in addition to amplifying, acts as an access point to high-frequency energy that vibrates in a quantum spectrum, without disturbing the physical system, and in perfect alignment with the natural resonance of the Earth.
Through this interaction of electrons and synchronization with natural harmonics, the energy in the circuit flows in harmony with the structure of space-time, without loss, without friction, and maintaining a structural coherence that can be sustained indefinitely in equilibrium. In the Metatron, free energy manifests in a pure and sustainable form, creating a quantum platform that represents the return of free energy to Earth, in sync with the universe and respectful of the very essence of nature."
So, is it possible to achieve this metatronic harmonic impedance state within a full microphone circuit? Is this why an almost perfect impedance match between a mic and the circuit/load sounds special? Is it even theoretically possible? Any ideas or perceptions on this may make for an interesting discussion. Thx in advance...
Chat GPT is wild
Chat GPT sometimes generates incorrect text, but it has trouble putting together text which is that far removed source documentation. It takes human judgement and ingenuity to put together that many words which just barely work syntactically, but are logically complete nonsense.
