VeinsDIYer
New member
Hello everybody
For our next album, we need to upgrade the studio gear, so I am thinking about DIY'ing 8-12 preamps to record drums. I have experience in components sourcing, PCB layout, and also have good soldering equipment.
I was pondering for 1173 clones to fit in a 500 series format. I was thinking that, since a good portion of the budget is for input/output transformers, adding EQ and compressor circuits on a line-level path between the PRE and the output would actually not impact the price much.
Do you have experience in creating custom channel strips with classic designs, such as 1173 + Caltec EQ + 1176/78 or even 33609?
Would the lack of an input/output transformer (if present in the original design) of the EQ and compression affect the desired tonal impact of the stage?
Is it a proper idea in the first place?
Thank you very much
Thank you very much
