jnTracks
Member
- Joined
- Jul 17, 2012
- Messages
- 19
Let me say, I really, really appreciate all the help and all the questions, noisy or not, in the service of trying to help me!
OK amp and board supply are both grounded, 3 prong.
In the supply I put ground wire to chassis, AC hot and neutral to the 120v transformer winding of all three transformers. The schemo here https://www.generalguitargadgets.com/pdf/ggg_ps_rps_sc.pdf
Is what I did, three of these in one box. (With different transformers and voltage regulators for each desired voltage). The grounds for each rail are common but separate from each other, and floating (not grounded to chassis) just as shown in the schemo.
I did wire all the output jacks for negative tip since it is more common, and to prevent confusion while building it, knowing I had a polarity reverse power cable that is a different color. So when my pedal board is populated it will be clear which power cable is reversed (different color) so I won't mix it up. I did test with DMM and confirmed that they all output negative tip, and the polarity reverse cable makes it positive tip. So polarity is reversed only once.
The noise only appears when the 12v is connected to the pedal. The 9v pedals and 18v pedals connect, power up, and operate fine from this supply.
