ChrioN
I've been looking for pentode preamps but without success.
Would be fun to try one out, but they seem pretty rare.
Anyone?
Anyone?
HiIt might be worth taking a closer look to determine if its repairable ,
You wont get any modern equivalent that looks the same ,
Only thing I can think of is maybe some old BBC or maybe Austrailian Broadcasting unit might have something similar ,
Sometimes if a moving coil meter is subject to a drop the pointer gets hung-up and doesnt move or wont zero out , you might need to re-adjust the set screws where the needle pivots , a tiny fraction of a turn anticlockwise and the needle should once again freely return to around the set 0 position , thats fine tuned with the screw adjust slot on the front of the meter .
The other thing that can happen is the glass panel in the front of the meter can get displaced and hamper the movement of the meter ,
My advice is take the meter apart , carefully dust it out with a soft paintbrush , check for bad connections or the mechanical missalignments I described above ,
Many thanks for the schematic!Royer 6AK5 mic pre:
I also had my difficulties with it at first, it is a voltage drippler for B+ and unregulated DC voltage for the heaters. Mr. Royer uses a similar one for his Royer mods, see here.Interesting power supply. Still trying to get my head around how it works.
I guessed as much but what puzzled me was that neither side of the transformer is connected to ground.I also had my difficulties with it at first, it is a voltage drippler for B+ and unregulated DC voltage for the heaters. Mr. Royer uses a similar one for his Royer mods, see here.
