Help troubleshooting noise please
sonolink
London-Madrid
I built this ab763 preamp into a stompbox with an added DI output. When using the DI out there's a lot of noise (like wind blowing). I measured the opamp and I get 4.5v pretty much on all pins except pin 4 (0v) and pin 8 (9v). I tried replacing the Opamp but no go.
Would that be a busted cap that is not filtering DC?
Any help would be greatly appreciated.
Sorry, now the correct schem is attached...
    470.7 KB
Do you have an oscilloscope to see what the dc booster is doing for B+? Switcher supplies can make interesting noises.
I do have an oscilloscope. Do you want me to check B+ with it? Just asking, but if the noise was coming from the B+ supply wouldn't it be present at both outputs? Those voltages at the opamp pins are they normal? If not, how would those 4.5vdc end up there?
Any suggestions?
Sono
4.5V DC on the input and output pins is correct in this case. The opamp is wired for unity, +1, gain by connecting the inverting input to the output. The opamp will settle at half the 9V supply voltage.
Are you getting the same noise when you bypass the tube section with the switch?
The stage driving the XLR is powered by a voltage that's dirtyed by the switcher.
It is very likely that the output voltage of the smps is cleaner that its input voltage.
Check what happens when increasing significantly C1.
Hi guys,
Sorry for not getting back earlier, I had a busy weekend :)
I just realized I was testing the unit using my MOTU Ultralite soundcard connected to my Macbook and the noise was coming from the laptop PSU 🤦‍♂️
I tried connecting it to a mixer and no noise at all. So problem solved :)
Thanks a lot for all your input
Sono
