djmiggymigz
Looking for some help understanding the theory behind this before I spend the money to buy the parts! Looking to replace the center indent pots on an eq I’m building with stepped and calculated switches. My plan is to use 1x12 non-shorting lorlin switches with resistors (calculated) soldered to the pins of the switch. So in theory, the restore should be wired in parallel to each other. Right? Meaning (and this is where I get iffy) that I can solder one leg of the resistors to the pins, and then simply connect all the free resistor legs together right? I’m including a little sketch of the way this works in my head. I only added resistors to pins 1 & 7-12 bcuz I can’t draw with depth lol. But the same resistor pattern would exist on all the pins. I might be missing the center post in the drawing?
One of my main questions, is after adding resistors to the switch, what switch pins correspond to the typical 3 pins of a normal pot? The build I’m working on send pin 1 and then pins 2&3 (connected) to the pcb’s. In the switch idea would those three pins correspond to pins 1, 12, and maybe the center ? How many center posts do I need?
(P.s. total noob here learning a lot. Please have patience if what I’ve said is fully wrong lol) also, I did a search and didn’t see a post dedicated to this hence the new post. Just saying that so nobody comes at me for not looking first
