GrannyGremlin
Active member
I think (yeasr ago) I tried using a tapering resistor with a linear pot in this sort of configuration & it didn't work too well. I think this is because it works when you feed the signal into the top of the pot & take the signal off the wiper, but the 9k doesn't use the rev log pot like this it only uses 2 of the connections & therefore you don't get the log law happening. You could just work out the resistors values you need to make a log switched attenuator & then hook them to the switch in reverse.
Wrong. Slugging resistors are good only for potentiometers connected as voltage dividers.
In the 9k, the pot is connected as a rheostat (aka variable resistor).
Oh sorry, I just assumed it would have been a voltage divider. With the things I've been working on lately I haven't seen a variable resistor gain control in a while.
.... [looking up the schem] Yep; says 2.5k though.
