CJ
what is this, another pipe dream?
well, this mic is so noisy stock that it sits in some dark place never to be used again,
i am going to try and replace the solid state stuff with a mini 5678 raytheon tube,
also, notice the cheezy 1 gig resistors, well we have some german 100 m glass resistors from a surplus score a dozen years back, so we will give them a try.
also, we need a BV-08, plus maybe some more bass, so we can wind 2600 turns and 400 turns on some 31 UI with a stack good for 750 henries instead of 150 like the stock version,
using the small tube makes more room for hi perm metal, oh yeah...
we have 30 volts on the capsule stock, so we can run this off of 48 phantom, no need for 5 terminal connectors or power supplies,
the tube takes 65 volts max so it too will run off of 48 volts, heater is only 1.25 volts but we need 50 ma,
anybody ever mod this cascade mic?
tube data:
http://www.mif.pg.gda.pl/homepages/frank/sheets/127/5/5678.pdf
tube data:
