CJ said:you must use the 48 right off the supply, not after 5.11 k resistors
Hi CJ, I really enjoyed reading this. BTW, you mentioned that original BV08 has 150H inductance. Did you measure the original or you just follow the info from AMI site? Also, 150H at 100, 200 or maybe 400 hz???CJ said:we need a BV-08, plus maybe some more bass, so we can wind 2600 turns and 400 turns on some 31 UI with a stack good for 750 henries instead of 150 like the stock version
