mattmartin831
- Joined
- Dec 11, 2016
- Messages
- 46
I am planning out my studio setup which includes a lot of DIY outboard gear, and I would like to be able to power all of it using one rackmounted power supply unit. I have a SMPS (rated 28V@5A) that I plan to convert to +24VDC with a 48V rail to drive my 8x Neve 1073 clones, +30/-10VDC to drive my 4x 1176 clones, and +/-16VDC with a 48V rail to drive my 8x API 312 clones, Harrison Ford filters, and SB4000 compressor. I plan to use a boost converter to generate the 48V phantom power rail, and I would use buck converters to create two negative voltage rails from the SMPS and use LM317/337 ICs to regulate the voltage rails to the values necessary for my applications. I have attached a drawing of my overall plan so far, but I have a few questions. Maybe some of you experienced DIYers can offer some advice:
1) I definitely want to make sure I don't damage any of my outboard gear, so would you guys have any advice regarding the values and types of fuses I should use?
2) Should I place rectifier diodes along each rail to make sure current only flows in the desired direction? If so, should I place the diodes at the beginning, middle or end of each current path?
3) I may consider adding a CAPI 500 rack sometime down the road. Would it be smarter to use a second SMPS to source the +/-16V rails in order to provide more current and to keep those rails electrically isolated from the others?
Feel free to point out any potential problems you see that I haven't thought of. I would be very grateful for any help you'd be willing to offer.
