Hi guys!
I'm a production student from the UK and I am plannig a DIY project for my dissertation for my final year. The project I had in mind is a combo of a preamp, eq and compressor, all built into one rack enclosure, not dissimilar to the UA 6176 and was hoping to get some advice/thoughts on the feasibility of this from all of you.
The plan is essentially to frakenstein together these two kits: http://www.audiomaintenance.com/acatalog/aml-17-020_extended_info.html
https://www.hairballaudio.com/catalog/fet-rack/fetrack-revision-acomplete-diy-kit
My plan to do is just to solder the output of the 1073 to the input of the 1176 and run them in series, however I do want to make a couple of mods and wanted to ask you guys whether this is possible and some pointers to parts that could make these mods easier.
The main mod I want to make is having only one power cable come from the unit, but I'm not too sure about the safety of joining two power supplies, so if anyone knows how I could do this safely, it would be greatly appreciated.
Another thing I'm worried about is grounding. Since both of these have to be ground to the chassis, would it be safe to ground both of these onto the same one? Also, I want to add switches so I could bypass the two units individually, but I'm not too sure about what the right switching mechanism/pcb would be for a rack compressor/eq, so any info on that would be greatly appreciated.
Initially I thought I'd be able to fit both of these into a 2U unit, but didn't realise how big some of the mains components are so its probably gonna be 3U, unless someone has some ideas how to make it fit into a 2U. The only way I could think of would be sodlering the pots to the board with wires instead of sodlering them directly into the pcb, but I'm not sure whether this would cause any problems with the range of the pots or anything like that.
I'll be designing a front pannel for it and will most likely end up buying a premade 2U/3U rack chassis which I will modify to build all of this stuff into.
I'd appreciate any type of feedback/criticism as I want to be sure that I can pull this off before buying most of the parts so that I can actually get it done. If anyone has any resources that could point me in the right direction I'd love that aswel. I have decent experience with soldering modular synths and pedals so at least I have that covered.
Thanks for any and all info! Much love <3
