Do you recognize the brand of these potentiometers?
trans4funks1
I am working with an old Groove Tubes Bass Pre (purportedly designed by SWR), that has been in storage and the pots and sliders are awfully "scratchy".
I would like to locate replacement parts in case the controls  do  not come back to life by being twisted, turned, and slid about.
I am hoping someone may recognize the labeling and point me in the direction of the original parts manufacturer.
Thank you.
not sure about that.
It does look vaguely familiar but there are (were) lots of cheap pot makers in Taiwan and mainland China last century when I was working in those ditches.
Purchasing was always finding new pot vendors who were too cheap to work right.
Thanks for the efforts.
Is it naive to think that there may be a standardized form factor in use that will allow for convenient replacement with another brand?
Thank you.
Thank you.
I don't think so..... Pucho posted a link to a bunch of GT schematics and manuals recently but I forgot where.....Maybe there is a part reference somewhere in there if you're lucky....Then you could look it up and get the dimensions to zero in on something.....
found the site...
https://aspenandassoc.com/schematics/
Pots like that (drop in replacements) use to be very common but within the last few years that have steadily been removed from the major electronic supply houses. But you should be able to find them on sites for guitar amp parts, Ebay or places like smallbear electronics.
B50K means 50 Kohms linear taper which is quite common:
Alpha Single-Gang 16mm PC Mount Vertical
Also you need to consider shaft type.
This place has a few guitar related pots..I've posted this link before....ASHLY recommended them to me so, they are trustworthy I'm guessing...
You need to know what dimensions you need ???
http://www.eyguitarmusic.com/Potentiometers_c_93.html
Get *good* pots which fit the panel holes. Solder short wires to the terminals and run them to the PCB. More reliable, and you don't have to hunt for exact terminal dimensions.
Maybe this???
https://www.ebay.com/itm/Fender-SWR-SM400-STUDIO220-AMPLIFIER-50K-POT-LINEAR-POTENTIOMETER-NEW-0066758000-/132451642283?_trksid=p2349526.m4383.l4275.c1#viTabs_0
Is SWR still around??? You could reach out to them...or Fender
SWR 220
